how do i forward a call from a caller
  • Updated 2 years ago
Photo of Glenda Martin
Glenda Martin
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
Not sure I understand what u mean by forward a call to a caller. Can u explain what the outcome your looking for is?
Glenda Martin
well when my son calls I need to forward his call to another person while he sits and waits for me to forward his call
Photo of Chadwick
How to activate Call Forwarding:
Press Star key (*) followed by 72.
Enter the area code and number you want your calls forwarded to.
Press Send or Talk (depending on your phone) and an automatic prompt will confirm the feature has been activated.
Photo of Chadwick
Also here is the link to that info. Click " how do I use call forwarding"
http://help.koodomobile.com/plans-add...
Photo of David
David, Mobile Master
  • 93,400 Points 50k badge 2x thumb
I don't believe you can transfer an incoming call to another phone number with Koodo's service. You MIGHT try three-way calling, then exit the call, leaving your son and the other participant in conversation, but I'm not sure it will work once you exit the call.
If you call forward incoming calls to your phone as Chadwick suggests, all incoming calls will be forwarded to that number, not just your son's calls.
If you can provide a bit more detail of what you are trying to accomplish, the community might be able to provide more suggestions.
Photo of grampad
grampad
  • 1,876 Points 1k badge 2x thumb
dfbutt, I think you are on the right track here and what I found was conference calling is device dependant so G Martin may have to consult the manual for that particular device.
