how do I change the APN setting on iphone to allow MMS messaging and not use data?
  • Updated 2 years ago
How do I change the APN setting on iphone to allow MMS messaging and not use data?
(iphone 5c or 6s)
Photo of Andre Fortin
Andre Fortin
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 187,512 Points 100k badge 2x thumb
Settings> Cellular> Cellular Data Network
Change the APN for Cellular Data only.
I just add an X to the front of it. This will mess up regular data, but since the MMS APN is correct, MMS will send normally
Andre Fortin
Thanks for the quick reply!
But what are the actual Koodo APN settings for MMS? And when you say, "just add an X to the front of it", what is "it"?
thanks
Photo of Dennis
  • 186,740 Points 100k badge 2x thumb
Andre Fortin
Thanks again for the quick reply!
I will try this later today on my daughter's phone.  I will let you know how it works out.
thanks again!!  :)
Andre Fortin
Sorry!  One more question, does the phone need to be unlocked to be able to edit the APN settings?  I have an Android phone and it is not letting me edit the APN setting - my phone is locked in to Koodo.
Let me know
thanks
Photo of Ivan
Ivan, Mobile Master
You should be able to change the settings. If it's not letting you edit, please try creating a new APN with the desired settings and make sure that it's selected.
Andre Fortin
thanks for the quick reply!  I will try it.  :)
