how do i call koodo from my cell phone?
  • 3
  • Updated 6 months ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: archiving 611
Photo of Kim Howson
Kim Howson
  • 102 Points 100 badge 2x thumb
Posted 8 months ago
  • 3
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
Dial *611.
But you can ask your question here. It might be quicker to get some helps.
Photo of Pedro Echeverri
Pedro Echeverri
  • 500 Points 500 badge 2x thumb
Dial 611
Photo of Suzanne Lise Ruck
Suzanne Lise Ruck
  • 92 Points 75 badge 2x thumb
611
Photo of Kim Howson
Kim Howson
Thank you.  It seems to be really tough to get a real person to talk to.  What I want to know is this...I see that I have gone over my minutes this month and I wanted to see if I could retroactively upgrade my plan and if so, how do i do it?  Do they really charge $10 to have a rep change your plan?
Photo of Mayumi
  • 114,698 Points 100k badge 2x thumb
They don't usually retroactive your plan...
What plan do you have and how many minutes in your plan?
When is your bill date?
Do you think your usage will be increase after next month or after upgrade your plan?
If it was just this month, then it might be better you just add "unlimited minutes minutes" Add-on for this month. I just want make sure what is the best option for you since they changed their Plan price.
You can change your plan through self serve, so IF you ask them to do it for you, then there will be a charge for that.
  Add : You could negotiate with them that you will upgrade to a more expensive plan and ask to waive the minutes overage for this month as trade off. There is no guaranty if they agree to do it, but asking is free ;)   This will work if you are ok with the new plan price and your need/wants matches.
Photo of Dennis
Dennis, Mobile Master
  • 195,746 Points 100k badge 2x thumb
Note that if you change plans mid month your former and new plan will be pro-rated.
Ex. if youe former plan was 100mins and you switched half way, then you get only 50 minutes, which may increase your overage
Photo of Andre Racicot
Andre Racicot
  • 90 Points 75 badge 2x thumb
holy could they take any longer to f'ng answer?
Photo of Dennis
What is your call in regard to?
Maybe we can help here?
