How do I block a specific phone number from calling or texting me?
  • 3
  • Updated 4 weeks ago
Photo of Jason Doerksen
Jason Doerksen
Posted 3 years ago
  • 3
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
Depending on your phone, you should be able to do that on your phone app. If not, you will need a 3rd party app
Photo of Ahmad
Ahmad
I think saying that it's possible without elaborating is just as helpful as not replying at all. OP probably already knows he can but wants to know how. I'll elaborate on what Dennis said. If you go into a text message with that number, or look them up through your call logs, hit then menu/options button (or it might be 3 dots in the corner of your screen) on your android and a menu should come up that has an option that says "Add to reject list". Click that.
Photo of Scott Veals
Scott Veals
  • 92 Points 75 badge 2x thumb
Thanks Ahmad.  On a Samsung S3, you access the "Add to reject list" by pushing on the button at the very bottom left of your screen, from within the specific number within either the call log or your contact list.  This button is often "invisible", i.e. does not have a symbol regularly showing up.  When the symbol does show, it's like 2 lines with a box over top of it, but no closed line on the bottom of the box
Scott Veals
However, now that I've figured out how to reject a call, it still goes to my voicemail, and I don't want this person to even be able to leave me messages.  So do I stop a number from being able to leave me a voice message?
Photo of Goran
Goran, Mobile Master
  • 88,672 Points 50k badge 2x thumb
You simply cannot unless the carrier supports a block list.
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hey Scott,
You can download an app called Mr. Number Call Blocker, it will give you an option so they can’t leave a voicemail and the call will just fail. I also use this app to warn me if the caller has been reported fraud or scammer.
Jason Doerksen
No dice so far, but thanks for replying. If I click on a number through my call log all the menu (or three dots) gives me is the option to Place On Home Screen. I have even tried going into the android default Messaging App but all it gives me are options for Messaging, not the contact/number themselves.
Photo of Ahmad
Ahmad
If you let me know which phone you have and what version of android you're on, I can tell you exactly what to do. To find the version of android you're on, go into settings -> about.
Jason Doerksen
Moto G. Android version 5.0.2
Photo of gaidheal mcintyre
gaidheal mcintyre
hellooo i have moto g 4.4.2  and dont  do apps    where do I put number to block as three dots dont give me add to voice mail option thanks  :)
gaidheal mcintyre
i have to  add to contacts first mmmmmm  then gets options thanks gaidheal haha
Photo of Freeapps Forme
Freeapps Forme
  • 60 Points
Of course, there are so many smartphones on Android that it is simply impossible to tell how the incoming calls are blocked on each of them individually. You can use the built-in Android tools and third-party applications to block unwanted calls and SMS. Both options are easy to use and require several minutes of free time. For which method to give preference to is the user’s choice.
Photo of Dennis
  • 183,688 Points 100k badge 2x thumb
Spam?  On a 2 year old reply
Photo of Goran
  • 87,556 Points 50k badge 2x thumb
Grasping at some straws here.
