How do I block a number completely from both messaging and calling on a Samsung Galaxy Ace? My phone does not allow me to manually do so.
Someone I know is harassing me and I would like to block their number completely. I use a Samsung Galaxy Ace and my phone does not allow me to manually block numbers. Do I need to call to have this done?
Photo of Emily Sadlon
Emily Sadlon
  • 90 Points 75 badge 2x thumb
  • triggered, nervous.
Posted 3 years ago
Photo of RudyW
RudyW
Fido has this, but I don't see koodo offering it. Maybe they should. You can use some of te record here though: http://www.digitaltrends.com/mobile/h...
Photo of Mathieu
Mathieu, Mobile Master
Hi Emily,
The Samsung Galaxy Ace does not support SMS/Call blacklisting on its own, you can take a look at what is available on the google play store though. Their are a bunch of applications that can do that for you, just by quickly searching I found this one here:
https://play.google.com/store/apps/de...
Take a look at it and other apps, find one that works for you and that is compatible with the phone!
Hope this helps!
