How do I add the pay per usage international plan for talk text and data?
  • Updated 1 year ago
I am going to Jamaica for 4 days and I dont want to pay for the $30 plan. How do I add pay-per-usage international roaming?
Photo of Kendra Miller
Kendra Miller
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 62,724 Points 50k badge 2x thumb
Login to self serve, click on view rate plan, then under your roaming add ons add the one you want!
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
If you add the $0 international roaming add-on, you will roam at a pay per use rate. This will suffice for sending a few texts or connecting calls to Canada for a maximum of a few minutes, otherwise you'd likely rather consider taking a roaming pkg before you go.
When you don't need to text or call through your Koodo line, you can leave your phone in airplane mode and just use it for photo/video :D
Kendra Miller
Where do I find the $0 international roaming add on? I only see the $40 and $15 options.
Photo of Allan
  • 62,624 Points 50k badge 2x thumb
http://help.koodomobile.com/coverage-...
Go the the link above and click on "International Pay-Per-Use Roaming". It gives you the steps to activate this add on.
Photo of Manj
Manj
  • 60 Points
Hi I'm trying the same thing but every time I press check out it gives an error: no financial data found. I'm currently traveling and would like to use my phone if need be.
Photo of Mayumi
Mayumi, Mobile Master
  • 115,066 Points 100k badge 2x thumb
In that case, you need to contact Koodo. Send a message through Facebook.
(You can click FB logo on the bottom of this page > Send message)
