How do I add my family memberss # in my phone plan?
  • 2
  • Updated 2 years ago
Photo of Christine Tomlinson
Christine Tomlinson
  • 190 Points 100 badge 2x thumb
  • indifferent
Posted 2 years ago
  • 2
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
Hello Christine.
Do you want to add them to your account so you can have unlimited call with them?
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Then, follow Dfbutt's suggestion :)
Christine Tomlinson
My family doesn't have koodo we all have our own accounts with diff companies
Photo of Mayumi
$20/mo "Unlimited Anytime Minutes" Add-on  give you unlimited calling to any Canadian number. It doesn't matter if your families are using different companies.
Your $30 plan includes 100 min + 100 MB.
If you don't need Data, then there is $40/mo Unlimited minutes/texts.
Christine Tomlinson
Okay I'll do that but how do I change over to 40/month
Photo of Mayumi
Have you register for self serve?
How do I register for Self Serve?
http://help.koodomobile.com/self-serve/registering/how-do-i-register-for-self-serve
Log into self serve > View Rate Plan > Change my plan > Pick new plan you want and submit.
Before you switch your plan:
1) Make sure that you compare what you will get and what you will loose after you switched your plan. (Is it worth it?)
2) Check your Usage and see how many days left in your current billing cycle.
Also how many minutes you used.
If you can give us those numbers(if you want), then we can give you better suggestion  .
If you activate your account recently, then you will not able to change your plan.
You have to call in and change your plan if you still want, but it may cause minutes overage charge due to proration.
I highly recommend to change your plan when it reset (or says 0 days left/last day of your billing cycle) to avoid it
Photo of David
David, Mobile Master
  • 88,962 Points 50k badge 2x thumb
Koodo does not have a 'Favourite Numbers' option. If a number of plans (max 6) are held within one payment account, as parents might do with children, calls between those plans are free.
Photo of Mayumi
If you want to add your family member under your account, you can do it if you are not under the spending limit program.
The easiest way is to go to the nearest Koodo store and buy a postpaid sim card and activate it under your account.  S/he will have her/his own plan and number.
Store rep will help you set it up :)
