How do I add data to my plan before I go over?
  • Updated 5 months ago
I'm about to go over my data plan this month. I don't find on the self-serve page anywhere to add data. How do I do this?
Photo of Kristine Dahl
Kristine Dahl
  • 160 Points 100 badge 2x thumb
Posted 5 months ago
Photo of Cory
  • 10,442 Points 10k badge 2x thumb
If you are on a shock free data plan, you will be prompted at 100% usage to purchase more data at the pay per use rate. Other than that, there may be other options available in your "add-on" section. I can see a $10 for 300MB in mine. Yours may differ, however.
You can check by going to "View Rate Plan", then "Manage Add-ons" after logging in.
Photo of Dennis
Dennis, Mobile Master
  • 177,292 Points 100k badge 2x thumb
For Shock free data plan it will give you an option for additonal data.  If you are not on a shock free data plan, then you just pay the overage rate set in your plan
