How do I activate pay per use roaming in the US?
  • Updated 9 months ago
I am on $30/month plan in Canada, last time I went to NYC, I attempted to send texts and they would not send.  I am going again and was wondering what I need to do to activate it.
I called koodo and the rep said Easy Roam is now the only option, is that correct? It's not practical for me since I only need to send a few texts over 4 or 5 days.  Please advise,
Thanks,
Photo of Ether Inlayo
Ether Inlayo
  • 80 Points 75 badge 2x thumb
Posted 9 months ago
Photo of Dinh
Dinh, Mobile Master
  • 41,278 Points 20k badge 2x thumb
In your case, pay per use is cheaper, you would just need to add 2 add-on on your account:
  • International Data Roaming
  • International Voice Roaming
Don't know if you can do it on selfserve, you could have to call in to ask them to put in on for you.
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
No you do not. If your needs are only some texting, you can rely on the pay per use rate for texts in the US, which is 5 dollars per 100 outgoing texts. Incoming is always free.
Also you do not in fact need those roaming add-ons Azure suggested for the US. There is of course no harm in adding them, but they aren't needed for US roaming.
If you need more than a few texts you can also opt for Roam Mobility by the day rates or just use Easy Roam if you end up having a day you need more or get a tourist sim from T-Mobile.
Ether Inlayo
How do I activate the pay per use roaming? Last time, i had signal in the US but my texts would not send.
Photo of Dinh
Dinh, Mobile Master
  • 40,754 Points 20k badge 2x thumb
Like I mentioned above, check your selfserve, if you see 2 addon:International Data Roaming and International Voice Roaming (and no easyroam), you are setup to use pay per use. Now, if you don't see it, I think you have to call Koodo or send message to their facebook to tell them to add it on for you.
Photo of Allan
Allan, Mobile Master
  • 61,520 Points 50k badge 2x thumb
You don't need those add-ons for US pay per use. They are only for international pay per use.
The lack of easy roam triggers US pay per use. Nothing else needed.
