how come my locked kodoo phone is using data even though im on wifi in the uk ? I have removed my sim card but my data is running up?
sim card removed but data is still counting on wifi ?
Photo of Archie Cardle
Archie Cardle
  • 170 Points 100 badge 2x thumb
Posted 3 years ago
Where are you seeing your data count going up?
Archie Cardle
I have a Samsung galaxy note 2, and I see it counting up on..settings>network connections>data usage button. Everytime I open a app I monitor it and I see the usage moving.. Im also in airplane mode. ive been here in Scotland since may 15th on wifi w the exception of using google maps for about 20 mins to get directions. And ive used 896 MB so far ...ive never seen it go up while being on wifi
Photo of Robert
Robert, Mobile Master
  • 103,928 Points 100k badge 2x thumb
It shouldn't go up. That's strange!
Do you see it going up on self serve also?
If the sim is out its impossible to use network data. Your counter is probably counting wifi. The note 2 isn't exactly a bug free device.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,242 Points 100k badge 2x thumb
From the data usage screen, tap the menu button and see if there is an option to include WiFi usage.
Archie Cardle
Robert, no I don't see it going up on self serve..last time it showed 155 mb used as of may 14th, the day before I flew out.
Archie Cardle
chad, I removed the sim at 6 am Scotland time may 18th. other than that I was on wifi connection from may 15th 10 am to may 18th at 6 w the sim in and no airplane mode set. I really do hope it is counting wifi usage
Archie Cardle
timo , you mean disable auto sync?
No, I mean what options show up when you press the menu button on the data usage page. There at least used to be an option to include wifi usage. If there is, make sure it's turned off.
Archie Cardle
auto sync data w a checkbox or one that says mobile hotspots
Photo of BobTheElectrician
BobTheElectrician
  • 62,198 Points 50k badge 2x thumb
Settings=>Data Usage leads to page with either Mobile or WiFi choices at top of page, as well as choice for data usage cycle.
Hit the = (settings) button at the bottom left to reveal 4 check boxes. Activate Restrict background... will stop some apps and services from working unless device is connected to a wifi network.
Archie Cardle
I don't see 4 choices..only 2..auto sync data and mobile hotspots
Photo of David
David, Mobile Master
  • 89,480 Points 50k badge 2x thumb
My Galaxy does not show Cellular data or Wi-Fi data choices at the top of the page if the SIM is removed, there is no indication at all, so I assume the data showing the graph must be Wi-Fi only.
Does your page look like this?
If so, make sure that you are looking at the cellular tab.
Archie Cardle
it similar w the exception at the top where is says cellular - wifi , it only says data usage and the 3 buttons at the bottom (triangle, circle, square ) are different on my phone
Photo of David
The Cellular tab and Wi-Fi tab do not show when the SIM is removed on my Galaxy. Likely the same for Archie.
Archie Cardle
even w my sim back in i still dont see 2 tabs only the data usage tab
Photo of David
I had to choose More > Show Wi-Fi usage on the Data usage page to see both tabs.
Archie Cardle
nope dont see any of that.
Archie Cardle
Archie Cardle
this is what i see
Photo of David
That was what I saw before I inserted my SIM and restarted my phone. Once I restarted I found the option to 'Show Wi-Fi Data' under the more button (missing on your screenshot; maybe the Settings gear?)
So far, just about all my data is Wi-Fi.
Archie Cardle
ive tried everything, cant find this "show wi fi data" at all ..i had a iphone over here last year w no sim, i had no problem w wifi
Photo of David
I doubt you're going to receive bill shock, as you have removed the SIM. It is funny you don't have a 'More' option showing on your screen, though.
Archie Cardle
thats my more screen
Look at data usage and press the menu button. That's the more option he's talking about.
If there is no sim in the phone there is no physical way that it can use cellular data, regardless of what the phone shows.
BobTheElectrician
Tempest in a teapot, laddie... did this experiment not 2 minutes ago.
Note II in Canada with SIM card inserted shows a choice of Mobile OR Wi-Fi data as per Timo above. Clear split between the 2 options, setting shows 4 choices.
Pull the SIM card, and it shows like Archie's, since there is NO WAY for the phone to access the mobile data with no SIM card. Settings shows 2 choices only.
Only way for phone to count data is thru Wi-Fi, actually stated in the original post.
Please do us the honour of checking your self-serve to see what usage Koodo reports. I suspect pulling the SIM card has alarmed you for nothing.
Pop in the SIM and turn on flight mode (no charges possible) and you will be back to the "normal" screen choice of Mobile or Wi-Fi.
Hope this soothes some frayed nerves a bit.
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Archie, if you removed the SIM card form your phone, it will be impossible to connect to any network. Furthermore, you would need the "International Voice Roaming" feature to enable international roaming on your phone, and then the "International Data Roaming" feature to enable data roaming http://koo.do/Im7Mcg. So unless you added these features on your account and your SIM card is still in your phone, you're most probably seeing WiFi usage and you're safe from a huge bill :) Enjoy your trip!
________________________
