How can I unlock my old phone (not my current one)?
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
Photo of Marilyne Comeau
Marilyne Comeau
  • 92 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
Marilyne Comeau
Yes, If I do it online I cannot see my previous phone, only my current one.
Photo of Dennis
iPhones must be called in to be unlocked. It cannot be completed online since iPhones are unlocked differently.
just tell them it was your previous phone on the account and give them the info they need (IMEI number) and it should be all good
Photo of Maureen Deptuck
Maureen Deptuck
  • 80 Points 75 badge 2x thumb
I received an unlock code from koodo before I left home to go to mexico. I put in the new chip and the code they gave me to unlock my phone and it didn't work. How do I get a correct code?
Photo of Dennis
You would need to call Koodo again.  The unlock codes are for Android phones, Windows phones, and blackberries.  iPhones may require an update with itunes
Maureen Deptuck
I can't find the phone number to call them again. I checked the web site and found nothing, can't remember where I found the number last time. I am in Mexico now and that makes things a lot more difficult. I will contact a friend with skype and see what I can do. Koodo doesn't make it easy to talk to them....
Photo of Ahmad
Ahmad
*611 from your Koodo phone or 1-866-995-6636 from any other phone.
Maureen Deptuck
Thank you so much! Eternally grateful!
Marilyne Comeau
Thank you !
