How can I tell if I have free incoming call's from the USA on my plan, and if I don't can I get it
  • Updated 1 year ago
Photo of Sandra Medd-Gillie
Sandra Medd-Gillie
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Sophia
Sophia, Mobile Master
Hi Sandra, as long as you are in Canada, incoming calls are treated the same no matter where in the world they originate from :)
Photo of Jru Gordon
Jru Gordon
  • 9,038 Points 5k badge 2x thumb
So if you have an 500 Minute Canada-Wide calling plan, an 5-minute incoming call from the US will count as 5 minutes out of your 500. If you're on an Unlimited Canada-Wide Calling plan, incoming calls from the US don't use up your minutes.
The only time you're billed anything extra is if you're calling from Canada to the US, which is 50cents a minute, or $10/mo for unlimited.
I don't believe there is an unlimited incoming US calling plan (EDIT-at least 1 that you can add-on if you don't already have Unlimited CW calling)
Sandra Medd-Gillie
Thank you for such a quick response
Photo of BobTheElectrician
BobTheElectrician
  • 61,576 Points 50k badge 2x thumb
There is an unlimited incoming call add-on if you need it (doesn't matter where the call originates as long as you are receiving it in Canada) for $10 per month.
Click on the monthly add-ons:
https://www.koodomobile.com/add-ons?INTCMP=KMNew_NavMenu_Shop_Addons
If you are using your cell to answer business calls from the US, it will be more attractive to your callers to obtain a local US or 800-number from a VoIP service and get those calls forwarded to your Canadian phone. Most US callers are accustomed to nationwide calling being free and will balk at calling a foreign Canadian number.
