How can I purchase a plan without buying a phone. I have my own phone.
Photo of SIMCITY
SIMCITY
Posted 3 years ago
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
If you don't have an account with koodo, You will need to open one
For monthly plan: The easiest way is to go to the nearest Koodo store and buy a sim card and sign up for monthly plan.They need to run a credit check on you. So bring proper ID when you go to a Koodo store.
http://help.koodomobile.com/getting-started-with-koodo/before-you-purchase/do-you-perform-a-credit-c...
For prepaid : Go to a Koodo store and get a prepaid sim and activate it. (no credit check)
If you have an account with Koodo already, log into self serve and change your plan through self serve.
