How can I get help without having to pay for it?
  • Updated 1 year ago
Vacation Hold
Photo of Ellie Hunt
Ellie Hunt
  • 82 Points 75 badge 2x thumb
Posted 1 year ago
Photo of David
David, Mobile Master
  • 83,270 Points 50k badge 2x thumb
Depends on the help you want. You can ask questions here, and the community will do its best to answer.
Photo of Mayumi
Mayumi, Mobile Master
  • 111,020 Points 100k badge 2x thumb
You can't change your plan to "Seasonal Hold" through self serve.
You will need to contact them. And they will not charge you since this is something you can't do it by yourself.
Note: Changing to Seasonal hold is plan change. So, you will need to pick up a new plan when you came back. If you have a grandfathered, then you will not get it back.
