How can I activate seasonal hold plan using self serve ?
  • Updated 2 years ago
I am a monthly plan user of koodo mobile. I am traveling out of Canada for 2 months.I am trying to find seasonal hold plan on self serve option but I cant locate it.If someone can please guide me how can I activate seasonal hold plan using self serve option I will be really thankful.
Photo of Aniket Dhepe
Aniket Dhepe
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Aniket,
You are unable to add a seasonal hold through self serve. To get one, you will need to call Koodo and speak with the representative. Do note that you will loose your current plan if you get a seasonal hold.
Photo of Bernard
Bernard, Official Rep
  • 75,526 Points 50k badge 2x thumb
@ Aniket, you are on plan that is no longer in market and indeed will lose it if you put your account on seasonal hold. The savings, based on your current plan, would only be $15 a month, so it may or may not be worth to do it. It's your call though.
