Hotspot/tethering Help!!
  • Updated 2 years ago
I want to tether my Moto G to both my laptop and/or my Ipad. I set the Moto G up and it seems to be sending a signal as both devices see it. I can select it on each device but that seems to be as far as I can go. I still can't get the internet to open on either or to transmit my mail. Is there something I'm missing?
Photo of Janice Anderson
Janice Anderson
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 107,634 Points 100k badge 2x thumb
In other words, the Internet does not work on your tethered devices? Does it work on your phone tho?
Photo of David
David, Mobile Master
  • 93,840 Points 50k badge 2x thumb
Edit you apn settings
Under Apn Type make sure "dun" is one of the types
Janice Anderson
The internet does work on my phone.
I'm new at this...where do I find the Apn settings to adjust?
Photo of Robert
Janice Anderson
OK..found the APN and there's nothing that says dun for a type
So you need to add it
Janice Anderson
dun is added under apn type but it still isn't working
Try restarting the device and then retrying to connect to it.
Janice Anderson
Hi Just back from work...sorry for the delay. The on/off suggestion after the changes has worked..yahoo. Thank you all for your help, really appreciated.
Photo of Yannick
Yannick
Good news, Janice! Have a great weekend :)
Photo of Yannick
Yannick
Hi Janice, did Chad's suggestion work? Keep us updated! Thank you!
________________________
Photo of BobTheElectrician
BobTheElectrician
  • 67,712 Points 50k badge 2x thumb
http://community.koodomobile.com/kood...
read the starred reponse for exact syntax of apn type, getting rid of the "supp" item
There is a chance it may not enabled on the phone. I have a few LG Androids from some "budget" US carriers and their particular models do not support tethering, probably because they are not interested in everyone going overboard on data.
Do you see a menu like the one on the fonarena page below? If there is no specific hotspot menu you may be out of luck.
http://www.fonearena.com/blog/88246/d...
BTW, tethering is a good way to really run up your data bill. Just checking emails and doing minor browsing can easily cost you 20mB a day since you will be dealing with the full-res version of most sites rather than the slimmed-down one tailored for the smaller mobile screens.
Photo of Mazaher Mohamedali
Mazaher Mohamedali
delete clearnet and telus apns it helped me
