Hoping for some help. Thanks
I have a Samsung Galaxy Ace IIx. I can connect to wifi at home,but when i try somewhere else I get a network error, also, it won't update games, (facebook). I have tried with data on, off, sync all on, off, I have no idea what else to try. Any ideas?
Photo of Sue Mike
Sue Mike
  • 80 Points 75 badge 2x thumb
Photo of PZABOY
PZABOY
  • 5,142 Points 5k badge 2x thumb
Try resetting your device and double check to make sure you have the correct APN settings.
Photo of Sue Mike
Sue Mike
Thank you for your reply. I guess I should mention, when it comes to the devices, i know absolutely nothing. lol. I haven't a clue about APN settings. Sorry. I have taken the battery out, restarted it. No idea how to actually reset it.
Photo of PZABOY
PZABOY
Well takin the battery is the proper reset so great job if its still not working double check your settings using the steps timo has listed below :)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Not clear from your post, when you are "somewhere else", are you connecting through wifi or through the cellular data network?
Which plan are you on? Are you sure that there was no data block add on added to the account?
for apn settings, go to settings->more settings->mobile networks->access point names, tap on koodo sp
these are the right settings:
APN: sp.koodo.com
Proxy:
Port:
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http://aliasredirect.net/proxy/koodo/ mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Sue, were you able to get the issue resolved?
________________________
