Home Phone on wireless network does that mean the handset is a wireless phone or smart phone or does it mean a cordless or corded phone?
  • Updated 2 years ago
It is available in my area of Summerside PEI and if I were to get this would I be able to purchase the Hub at $40 and the Sim Card at $10 all for a one time fee the Telus Store as I only have a Mobile Shop Kiosk in my area? Does this require a credit check?
Photo of Terri Henderson
Terri Henderson
  • 144 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
It works the same as a normal home phone except that the service is through the cell towers. The handset cannot leave the normal range of your home. Only available at the Koodo booth.
Read more here please
https://community.koodomobile.com/koo...
Photo of Chadwick
It has to be activated through Koodo not telus. Also no credit check is required if Ur doing it on an account already current with Koodo
Terri Henderson
Oh ok. I'm only a pre-paid customer. So that would mean a credit check?
Photo of Chadwick
You would need to open a line. So yes, normal procedure. 2 pieces of I.D and a credit check at the time of signing up. U can have a family member open it for you.
Terri Henderson
Thank you for the information.
Photo of Chadwick
Hey not a problem. That's why we're here.
Photo of Mathieu
Mathieu, Mobile Master
Hi Terri,
You would need to buy it at a Koodo retailler. You purchase the hub for 40$, 10$ SIM card as you indicated, so a total of 50$ to get started and a cost of 20$ per month. You can plug any home phone into the box. So any phone you have plugged into the wall, you would just plug into the hub instead. There are 2 available ports on the hub.
