Home phone doesn't ring
  • Updated 12 months ago
Home phone hub is connected to my home phone. I can make calls on, but can't receive calls
Photo of Carrie Mason
Carrie Mason
Posted 12 months ago
Photo of Allan
Allan, Mobile Master
  • 62,896 Points 50k badge 2x thumb
Did you recently port the number? Can you not receieve calls or does the phone kust not ring? Do the calls go to voicemail?
Carrie Mason
I port the number, it rings about 5 times then goes to voicemail.
Photo of David
David, Mobile Master
  • 93,850 Points 50k badge 2x thumb
Voicemail on your WHP, or at your old provider?
Is the ringer volume turned up on your handset?
Carrie Mason
It is working now.
Photo of Allan
  • 62,876 Points 50k badge 2x thumb
When you port the number it can take a few hours to completelt have everything working. Glad to hear its all fixed!
