Home phone does not hang up after a caller leaves a message on an answering machine
  • Updated 2 years ago
Hi, I signed up for home phone service and hooked up my answering machine to the zte box. When a caller hangs up after leaving a message, I get a busy signal and the answering machine continuously records until I manually hang up the phone. I've read that a certain signal from the carrier needs to be sent in order to disconnect. Could this be my issue? It never happened on my Bell line. Thanks.
Photo of SirloinofBeef
SirloinofBeef
  • 112 Points 100 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
  • 89,044 Points 50k badge 2x thumb
Koodo home phone is does not support answering machines, fax machines, or alarm systems. You may be wisest to use the provided voicemail system instead.
SirloinofBeef
Thanks.  Would you know if this a hardware limitation or carrier?
Photo of Sophia
Sophia, Mobile Master
It's definitely a hardware limitation, because Koodo as a carrier wouldn't mind you using your own answering machine at all. Someone posted a very detailed explanation of why this is the case, I'll see if I can find it and post the link here...
Photo of Sophia
Found it, here you go: https://community.koodomobile.com/koodo/topics/can-koodo-wireless-home-receive-faxes
The question has more to do with faxes but read the explanation "demon_390" provided, I think that might be an explanation for your problem as well.
SirloinofBeef
Thanks, the zte 721 manual seems to say that answering machines are ok to hook up.  Will find out form Koodo.
