home phone antennas
  • Updated 7 months ago
can I use a different antenna to improve my reception if I'm in a weak spot. I notice it has an external antenna so reception should be better than my smart phone but I might need a bit more gain
Photo of Stephen Tilston
Stephen Tilston
Posted 7 months ago
Photo of Goran
Goran, Mobile Master
  • 90,940 Points 50k badge 2x thumb
There's no reason why you cannot use a better antenna if you have one.
Stephen Tilston
ok thanks. or maybe just make a reflector for it.
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hey Stephen,
The ZTE wireless home phone is built to work on one bar of service. Are you having any signal issues?
Stephen Tilston
I don't know yet. I haven't got the home phone yet but I'm considering it. Coverage is really spotty with my smart phone (Galaxy A5) but I was thinking if I used a higher gain antenna on the home phone it would help. The external antenna should be better anyway but putting a reflector behind it and aiming in the direction of the tower should make a big improvement.
Photo of Dinh
Dinh, Mobile Master
  • 32,772 Points 20k badge 2x thumb
The antenna of the ZTE is removable, and used a standard connection (looks like so, I haven't tested my self). You could buy a antenna on amazon and replace the OEM.
This one might work https://www.amazon.ca/Lysignal-700MHz-2700MHz-Omni-directional-Antenna-Cable/dp/B01J5A3RYG/ref=sr_1_...
Stephen Tilston
It might. Thanks.
Photo of David
David, Mobile Master
  • 89,014 Points 50k badge 2x thumb
You can also place the WHP device in a location that gets the best signal in your house, and use cordless phones around the house for calling.
