Hi Just setting up a home phone and I'd like to know whether, an incoming call will go through to the voicemail in my cordless handset?
  • Updated 7 months ago
Hi
I am just setting up a new  WF home phone and I'd like to know whether, if I don't set up the Koodo voicemail, an incoming call will go through to the voicemail in my cordless handset?  Thanks for any help
Photo of KEITH
KEITH
  • 242 Points 100 badge 2x thumb
Posted 7 months ago
Photo of Dennis
Dennis, Mobile Master
If your handset picks up the call before the Koodo system then it will accept the voicemail.  Otherwise the Koodo system will pick it up.
Photo of KEITH
KEITH
Thanks for the fast reply.
 Since the call goes through the Kodo system before the handset,  not sure how the handset can pick up first?  Any method of ensuring that the handset is first?
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
I expect Dennis means your answering machine must answer in fewer rings than does Koodo's voicemail system. You would also have to address what happens when you are on the line, and a second call is made to your number. In most instances, Koodo's VM would pick up, as your answering machine can't do so.
Photo of David
You can check the options here to see if changing call forwarding options will prevent calls going to the voicemail system.
Photo of Dennis
  • 186,880 Points 100k badge 2x thumb
Yea I guess it wont work if you are on a call.
Just wondering, why do you prefer your answering machine over Koodo's voicemail?
Photo of Dinh
Dinh, Mobile Master
  • 32,212 Points 20k badge 2x thumb
The answering machine is better, it normally has louder volume and better voicemail controls. Customers also don't have to dial to Koodo VM.
The only disadvantage (or advantage of Koodo VM) of the answering machine was the remote access to Koodo VM when you are not at home.
Photo of KEITH
KEITH
As Azure.  With the AM it is also easy to see if you have a message and a single press plays any messages.
I have one Koodo home line for business use and the VM is fine for business users used to accessing voicemail with a password and listening to the options, but my wife will go nuts dialling the Koodo VM every time - if she even notices the very small message indicator.
The biggest advantage though is that we can listen to a message being left and decide to answer or ignore it.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
I know that koodo does have the ability to disable voicemail on the wireless home phone; I got them to do it for me, for the exact same reason. (I tend to use the answering machine to screen calls). I don't think you can do it without calling in (or contacting them via facebook) though.
Photo of KEITH
KEITH
Thanks everyone.
Great help  to a newbie
