Hi im going to us for few days , and will have my phone ,do i need any add ons , and what are call costs ? Mr s rathbone
Photo of Heather Kennedy
Heather Kennedy
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Mathieu Carrier
Mathieu Carrier
  • 4,124 Points 4k badge 2x thumb
Here are the pay per use rates:
1.50$/min
5$/20Megabytes
5$/100 outgoing sms (Incoming are free)
Koodo also has several add ons to reduce the cost of pay per use!
It all depends on how long you go for and what you want to use :) Let me know and i will tell you what packages are availible!
Photo of Mathieu
Mathieu, Mobile Master
Hi Heather,
You can take a lool at the US Add-ons available and find the one to fit your needs at this link:
https://www.koodomobile.com/add-ons
There are also instructions as to how to add it to your account in the description or the add-ons
Hope this helps!
Heather Kennedy
Hi it will probably be for emergency calls only, as long as i can use it in US just in case thanks steve
Mathieu Carrier
Hey i would then recommend just going with those pay per use rates it will be cheaper than getting an add on since it is for emergency calls.
Photo of Dennis
Dennis, Mobile Master
  • 196,722 Points 100k badge 2x thumb
Hi Heather / Mr/s Rathbone / Steve,
This link will help
http://help.koodomobile.com/coverage-...
