Hi ! If i'm traveling to London, and I only use my phone on wifi will I be charged roaming charges just for having it on?
  • Updated 1 week ago
Hi ! If i'm traveling to London england from canada, and I only use my phone on wifi will I still be charged roaming charges just for having it on?
Photo of Brittany
Brittany
Posted 2 weeks ago
Photo of David
David, Mobile Master
  • 93,716 Points 50k badge 2x thumb
No, but leave it in Airplane mode or remove your SIM card if you’re really concerned..
Photo of Robert
Robert, Mobile Master
  • 107,280 Points 100k badge 2x thumb
Airplane mode may have some data leakages some times, so you're best bet is to disable cellular data AND airplane mode.
Photo of Shutdown
Shutdown
  • 452 Points 250 badge 2x thumb
If you take out your sim there is no way they can charge you to be safe and if you have iphone they have that wifi assist thing that can use data when wifi signal is weak. In that case you will be charged a ridiculous amount.
Photo of Dennis
Dennis, Mobile Master
  • 196,488 Points 100k badge 2x thumb
Restarting a phone can also incur data leakage, so removing the sim is really the only sure way to guarentee no roaming charges
