Hi, I recently started using prepaid with the $15 base plan then added talk and data boosters
  • Updated 5 months ago
Hi, I recently started using prepaid with the $15 base plan then added talk and data boosters... however I dont think my settings are configured properly?  As I dont seem to get regular texts from other iphones ( which seem to default to imessaging) and I cannot get email etc to open when not on wifi.. when I looked under "cellular" there is a space for username and password in data but obviously this is blank... just wondering if there is any advice as the help section basically only says when bringing your own iphone to reset it as new and insert sim card ( but this is a brand new phone from the apple store so this would have been the case when the sim was put in...?)
new iphone x ( yes yes pretty fancy phone to be doing prepaid but its more of an emergency phone and handy to have as a camera and to make and receive texts related to appointments etc)
Photo of denise
denise
  • 194 Points 100 badge 2x thumb
  • lost!
Posted 5 months ago
Photo of Allan
Allan, Mobile Master
  • 56,726 Points 50k badge 2x thumb
Is it just texts that you receive on and off? Everything else seems to be working fine?
Photo of denise
denise
David thanks :) I did this and its on but one thing I AM noticing is under cellular data >cellular data network>it does seem to have a space for username and password.. which are blank... but I am thinking this is to do with setting up a personal hotspot and not data useage itself?
I make sure that the appropriate things are data enabled and data is on but still a no go
pondering if I should back my iphone up and reset even though its a new phone..? maybe a hinky setting?
Photo of David
David, Mobile Master
  • 89,044 Points 50k badge 2x thumb
Yes, those username and password spaces should be empty.
Photo of David
Yes, could be a odd setting. Backup and restore may help.
Photo of David
Can you access internet for other things?
Photo of denise
denise
Thanks David... no internet unless I am connected to wi-fi
I will try a backup and restore tonight ?
Photo of Riley Marques
Riley Marques
  • 60 Points
Mine is like that too and I haven’t got any texts since my base plan ran out, now I put automatic top ups and stuff but it still doesn’t work, and my texts don’t go through..
Photo of Allan
Have you put more money on the account so that you have an active base plan?
Photo of BobTheElectrician
BobTheElectrician
  • 61,920 Points 50k badge 2x thumb
Admittedly, the website and some aspects of customer service for prepaid are far from ideal.
The automatic top ups ONLY work once every 30 days when your baseplan is due to be renewed. The first time round, you have to add $$ manually, then the automatic ones kick in regularly on your anniversary date.
You can't order boosters and expect your auto top ups to automatically adjust in mid stream to pay for them. It's less confusing if you add the necessary $$ first and confirm your balance before ordering boosters.
Photo of denise
denise
My issue is not waiting for things to be connected as a pre-existing customer? I set up a NEW account three days ago? on a brand new phone and now I just don't think data is set up correctly and wondering who to talk to or how to fix it... it uses maybe 0.0001 mb of data on "basic phone services" but then it won't access email etc and any texts coming in that are imessages are not being received until I connect to wifi ( so clearly data isn't working on there either) I know someone else replied with same issue but as a pre-existing customer and this is not the case for me/ Any help is appreciated
