Hi, I need tec help from a mobile master... how do I reach one?
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: Self-Serve app metions
Can someone please message me.... I need to add on international text messaging but cant do it from outside Canada....I need guidance,  its urgent. Tnanks
Photo of sroutledge .
sroutledge .
  • 112 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 90,800 Points 50k badge 2x thumb
Are you unable to use a local Sim? It's août without exception cheaper to do so and then gets you data to use VoIP apps so you can be called or texted from Canada for people without international texting. Looks like so long as you have a connection to a roaming network with voice working you can text the add-on codes to 7626. Alternatively you can use self-serve app with a wi-fi connection to add the free international add-ons a then add the add-on you wan for texting.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,132 Points 100k badge 2x thumb
You should be able to add it via the self serve app. Don't forget to add international voice roaming, under other add ons, though, otherwise the phone will not connect to the network.
Photo of Bernard
Bernard, Official Rep
  • 75,644 Points 50k badge 2x thumb
Try it now Sam. It should work.
sroutledge .
Thank you, got it now.
