Hi, I just changed my plan from 500mb to 750mb mid way through my cycle. How many mbs can I use this month? Will it be 675mb? Thanks.
  • Updated 2 years ago
Hi, I just changed my plan from 500mb to 750mb mid way through my cycle. How many mbs can I use this month? Will it be something like 675mb? Thank you.
Photo of Justin Meskas
Justin Meskas
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 97,236 Points 50k badge 2x thumb
Let's assume you mean exactly midway to make the calculations simple. For the first half since you did 15/30 on the old plan you get 500* 0.5 = 250 MB of use for the first 15 days and then in the second half of your billing cycle you will get 750 * 0.5 = 375MB of data to use. If you go over or did go over 250 or 375 in either half you will pay overages unfortunately.
