Hi, I have a plan with you including 1go but I would need for one month to boost my plan up to 3-6go, do you have that option?
Photo of Mai LeBel
Mai LeBel
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Ahmad
Ahmad
There is no option to add-on extra data. Instead, you just use your rate plans overage rate on data. This can be found on self-serve under Plans & Add-ons. Your overage rate is plan specific. Some people have an overage rate of $10/GB and some have an overage rate of $10/250MB. It just depends on the plan. But regardless, there is no add-on and if you want to use more data, you just pay your overage rate.
Photo of Sophia
Sophia, Mobile Master
Do you mean 1GB, Mai? No, you only have two options, use the 3-6GB and pay the overage... or upgrade your plan to a higher one I'm afraid.
Photo of Mai LeBel
Mai LeBel
yah GB, french took over on this one..
I don't want to change my plan, because it doesn't exist anymore and it's way more nicer than the current offer... do you know how to find my over rage?
