hi, how could I put my plan on hold?
  • Updated 2 years ago
  • (Edited)
I'm traveling abroad so I need to put my plan on hold. how can i do that?
Photo of Ali Gh
Ali Gh
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
You will need to call Koodo, or contact them privately on Facebook.
Note that this will count as a plan change, meaning that after you come back, you can only select one of the then available plans. Cost is $15, depending on the length of travel and remaining Tab, you might want to choose other options (keep your plan alive, or port out to a VOIP service/7-11 prepaid plan)
