Hi! Could use some help with some cellphone frequencies! I have an Eastern Phone
I need to find a carrier that will have the correct frequency. I have a new Andriod Lenovo fliip phone, here http://www.amazon.ca/Lenovo-MTK6582M-Google-Android-Screen/dp/B00SCM9GV2
I need to know which carriers it will work on. Thanks! Shawn
Photo of Shawn Bibby
Shawn Bibby
Posted 3 years ago
Photo of Todd Leblanc
Todd Leblanc
  • 880 Points 500 badge 2x thumb
This phone appears that it will work on 3g on the koodo/telus towers
This device is not compatible with any 3G or higher carrier in Canada.
Todd Leblanc
I was looking at an wrong source then my bad
No problem Todd, for future reference koodo uses
3G HSDPA 850/ 1900 MHZ & LTE B4 (1700/2100mhz)
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
I'm not so sure about those 3G numbers. 2G is a dead issue in Canada except for some older Rogers equipment. You can always drop by a boutique and check it out.
Then nope, it should work on 2g as long as the network type is set to wcdma/gsm auto with either Fido or Rogers
Shawn Bibby
So maybe retry another rodgers/ fido store is my best chance huh?
BobTheElectrician
Dual SIM means that it will only look for data on the "main" SIM, second SIM is severely restricted. Designed for frequent travellers with a home base or business people who want to handle a second line from the family and other personal calls.
Bob, that second sim limitation may not be true anymore. My blue hd is dual sim and both slots are identical
For 2g it's your only choice in Canada.
