Hey. I need to chat with someone about issues with mobile network. I can't use my phone to make calls bescause network is down.
  • Updated 4 months ago
Photo of François Landry
François Landry
  • 190 Points 100 badge 2x thumb
Posted 4 months ago
Photo of Allan
Allan, Mobile Master
  • 56,746 Points 50k badge 2x thumb
Have you tried restarting your phone and removing and reinvesting your sim card?
Has it worked in the past and now doesn't? Is it just calls you can't make, (do texts work)?
Do you have any bars of service?
Photo of Dinh
Dinh, Mobile Master
  • 32,934 Points 20k badge 2x thumb
Hi Francois,
What did you see on your phone when the network is down? no signal? or "no service"?
Have you checked your selfserve? what did it say?
François Landry
Well, it is just the network that does not seem to work. Phone is ok.
It used to be all good until a couple days ago.
Photo of Allan
Have you tried restarting like I mentioned?
François Landry
I'll try.
François Landry
??? It works. But why does it work? What kind of wizard are you?
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
Sometimes a simple reset is what it takes to solve a problem because it triggers a reconnection to the network
François Landry
When I try to call it says "mobile network unavailable" (translation from french)
François Landry
Problem solved. Thanks a lot.
