Help with setting up prepaid plan on Nexus 4
My phone is an unlocked Nexus 4
I just got a Prepaid MicroSIM card and followed the instructions to set it and ported my phone number from SpeakOut to Koodo.
I then followed the instructions on this page (http://koodomobile.com/en/on/switch2k...) to configure my android phone with the network and retarted... However, it says under the status page of my phone that "Mobile Network Status: Disconnected"
I cannot send or recieve any SMS.
Photo of Tim Lou
Tim Lou
How long ago did you port out?
Photo of Tim Lou
Tim Lou
Maybe 2 hours ago...
Oh and make sure under settings that "use gsm only" or "use 2g only" aren't selected. Koodo doesn't support this mode.
Photo of Tim Lou
Tim Lou
Yes, I made sure those are not selected
Are you able to make phone calls?
Photo of Tim Lou
Tim Lou
Nope, it says "we cannot complete your call, the call is not covered under your plan and you do not have an active booster"
I'm on the 15 dollar texting plan. I don't think I'm going to invest anymore and buy any boosters unless I can get basic SMS working first.
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Something must've gone wrong, even if you are porting your number and there is an error in the porting, the account is supposed to have an active status if you completed the whole process online... At this point if you say that the whole process was completed and you had a confirmation on the website that the account was activated, I would call Customer Service to check the status of the account and see what really happened... Have handy all the info you have from your previous provider, like Account number, Pin number, EMEI from old phone, this will be required to complete the whole port process...
Photo of Tim Lou
Tim Lou
I think it was completed, because when I log into the prepaid webpage, it lists my phone number as the one I ported over. Also, the account status says "Service Status: Active / Actif"
It has already charged me the 15 dollars, so I assume the service must be active in that case...
There is never a charge for tech support so give koodo a buzz and see if something is wacky.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,100 Points 100k badge 2x thumb
Just to check, your using the stock messaging app and not a 3rd party right? I've heard of some issues with the Nexus 4 and some 3rd part messaging apps
Photo of Tim Lou
Tim Lou
Ya its the default app from google.
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
My guess is that port was not completed, you should give a call to Koodo to be sure it was.
