Help with setting up nonkoodo phone to send and recieve text messages.
I recently bought an unlocked phone. Its an android smartphone.
I am able to make calls, send and recieve photo messages, but simple text messages will NOT send. I went through and manually configured the APN with koodo settings. What am i doing wrong???
Just now I put the sim back in my koodo Samsung evergreen and it is now not sending text messages.....
Photo of Mel
Mel
  • 1,044 Points 1k badge 2x thumb
Photo of Dennis
Dennis, Mobile Master
  • 187,596 Points 100k badge 2x thumb
It should work. Sounds like the sim card may be damaged
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,062 Points 100k badge 2x thumb
open the messaging app
tap the menu button
select settings
make sure the messaging center is set to +16475800172
this is the number through wihch all koodo sms messages are relayed. if it's wrong, they won't send.
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
Take the sim card out then restart the phone. after the phone boots then put the sim card back in.
