Help with phone screen
  • 2
Someone tried to unlock my daughters screen lock on her phone with the wrong passcode many times today at school. Now the phone is saying she has to enter her google account info....the problem is she doesn't have a google email...
Photo of Polly Rice
Polly Rice
  • 80 Points 75 badge 2x thumb
  • 2
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
You're going to need to do a factory reset with the phone buttons. What phone do you have?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,746 Points 100k badge 2x thumb
In an attempt to resolve the issue through carpet bombing:
Samsung Galaxy SII X
• Take out battery, memory card and SIM
• Put battery back in phone.
• Hold down POWER/LOCK + volume up and down (hold rocker in middle) for 3 seconds
• Scroll with volume button to wipe data/factory reset. Press power button to select
HTC ONE V
If you can’t turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button
LG Optimus One
• Put battery back in phone (DO NOT TURN ON)
• Hold down the POWER/LOCK Key + HOME KEY + DOWN VOLUME KEY for approx 10 seconds until phone starts to come on. Release the buttons as the phone comes on.
• Phone will reset as it comes on.
LG Optimus CHAT (LG C555)
• Hold down the POWER/LOCK key + SEND key + DOWN VOLUME at the same time for approximately 10 seconds until phone starts to come on.
• Release the buttons as the phone comes on.
Samsung Galaxy Ace
• Hold down POWER/LOCK + HOME for 3 seconds
• Scroll with volume button to wipe data/factory reset. Press center button to select
• Scroll with volume button to YES and select with center button
• Once wipe complete select reboot system now with center button
• Phone will power up on its own, wait for arrow and menu button to light up then follow steps
Samsung Nexus S.
• Press VOLUME UP + POWER
• Scroll to recovery with volume button and select with power button
• When you see the exclamation mark [!] and the Android, you should hold down the POWER Button and then press the VOLUME UP, while still holding the POWER button. (DON’T press both at the same time.)
• Scroll with volume button to YES and select with power button
• Once wipe complete select reboot system now with power button
• Phone will power up on its own then follow steps
