Help! Samsung galaxy SIII issues
I have a Samsung Galaxy SIII and whenever I try to get my phone going after charging the screen stays black and just the bottom buttons (menu/back) light up. It's only three months old... Anyone have any ideas on how to fix it? I did a factory reset and that didn't work...
Photo of Shannon
Shannon
  • 84 Points 75 badge 2x thumb
Photo of Mayumi
Mayumi, Mobile Master
  • 115,204 Points 100k badge 2x thumb
Was it working before?
If a factory reset didn't work...I would bring it to the nearest Koodo store, and ask whether it can be sent by repair under warranty.
Photo of Shannon
Shannon
It does still work....kinda... I have to take out the battery and restart it every time I want to use it and it works great until it has to be charged again then I'm back to the black screen.
Photo of Mayumi
If you have to take the battery out and in every time you charged it, I think there is something wrong with the device. I would go check it out.
Photo of Yannick
Yannick
Hi Shannon, Mayumi is right. You should go directly to a Koodo store so a representative can have a look at it: http://koo.do/locator123. If you live too far from our stores, you can also call us at 1-866-995-6636 from another phone, option #6. To find more info about the warranty and the repair process: http://koo.do/JVO5Mk. Thank you!
________________________
