how can you turn on caller ID? Every time I get a call from someone on my contacts it comes up as an unknown caller.
Photo of Jake Boer
Jake Boer
  • 90 Points 75 badge 2x thumb
  • frustrated
Photo of Starfox
  • 5,718 Points 5k badge 2x thumb
You need to have the feature first. Check you bill to see if you have the feature bill separate or part of the plan. usually if it is part of the plan, there will be a "CD" in the name of the plan that represents the call display
Photo of ALicia Foster
ALicia Foster
If it is not included, you can go to your nearest koodo provider and they can easily set you up. I believe it is only an extra 2-5 dollar fee.
Photo of Stephen Shakeshaft
Stephen Shakeshaft
  • 92 Points 75 badge 2x thumb
If you don't have it you should be able to add it to your plan from the website or smartphone app.
Photo of Jaclyne Edmondson
Jaclyne Edmondson
  • 232 Points 100 badge 2x thumb
I am paying extra for caller ID monthly. Sometimes they have packages or deals for caller ID. But if not, I believe it is a $5 extra charge. I got a package deal when I got mine and I have voice mail and caller ID for $7 a month instead of $10. So make sure you ask a Koodo representative!
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
Remember that the name won't show up unless its in your contact list.
