Help, my outgoing email settings seem to be wrong??
Hello,
I've looked at a few postings, but haven't been able to solve my problem with the smpts and ports suggested. Incoming mail is fine, but when I try to send an email I get this message or try to set up the outgoing mail server: Unable to connect to email server to verify your account info. no response from server.
My phone is a Samsung Galaxy S2 Ace, koodo data plan with Cogeco as my mail server. Any ideas?? This is my first smart phone and I got it yesterday, so not to savvy with it yet.
Photo of Laura Robinson
Laura Robinson
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
Try these settings:
cogeco.ca POP3
Incoming Server Name: pop.cogeco.ca
Port: 110
Use Authentication: Yes
Use SSL: No
Outgoing Server Name: smtp.telus.net
Port: 25
Use Authentication: No
Use SSL: No
Laura Robinson
Thank you, Thank you!! As soon as I saw your post, I knew what I had done wrong. I tried telus.ca, not .net. I appreciate your fast response and very helpful answer. Now its working great!
Photo of Chasidy Jensen
Chasidy Jensen
  • 90 Points 75 badge 2x thumb
Hey i had the same question, my outgoing is not working to send my buisness emails, i alwasy have to refer back to my hotmail to send the emial out
please help
Chasidy Jensen
i have an iphone 4 with koodo
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,242 Points 100k badge 2x thumb
Through a 3g data connection the outgoing server should be smtp.telus.net, port 587, no authentication, no ssl.
The iphone will also allow you to setup multiple outgoing servers, which may be necessary in order to send emails over both wifi and 3g (most network operators block email sent through 3rd party servers to help reduce spam).
Chasidy Jensen
What other outgoing server do u suggest?? i just need to be able to respond from my work email...
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Aside from the smtp.telus.net
Port 25
you would need to contact the person/company that provided you with that work email to get the other outgoing settings
Chasidy Jensen
okay, thank you!
