HELP ME..MY VOICEMAIL NUMBER GOT ERASED!!
  • 4
My Android Samsung Galaxy has erased my voicemail number and replaced with another person's phone no.? Please help me..I need step by step instructions to find my voicemail phone number and re-set Please!
Photo of Debbi Slaven
Debbi Slaven
  • 190 Points 100 badge 2x thumb
  • 4
Photo of Ivan
Ivan, Mobile Master
Open up your menu in your phone dialer (three dots in the corner). You'll be able to find voicemail settings there.
Your voicemail number is 1+your area code+your phone#.
Photo of Dennis
Dennis, Mobile Master
  • 187,452 Points 100k badge 2x thumb
Timo has a good answer here
http://community.koodomobile.com/kood...
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,002 Points 100k badge 2x thumb
The koodo vm access number should be listed as something similar to +16475804001. There are multiple different numbers depending on which voicemail server you are assigned to, but most end with 4001, 4002 or 4003. If this looks like the number programmed into the phone, don't change it until you test the voicemail.
