Help me I'm stuck on the loading android page for almost one hour...
I have a LG Optimus One and I tried to open my phone but i'm stuck on the loading android page! I don't know what to do... My phone is stuck at this page for almost 1 hour
Photo of Laurence Piette
Laurence Piette
Photo of Sophia
Sophia, Mobile Master
Hi Laurence, is this the first time that you opened the phone? You didn't try to update the phone did you? If not, you could try to remove the battery for a few minutes and put it back, see if that solves the problem. :) Let us know, otherwise people can help troubleshoot further :)
Laurence Piette
It's not the first time that I open my phone and I tried to remove the battery but t doesn't work. I'm stuck on the loading android page.
Photo of Sophia
Aww!! Is it an Android that is sort of lying on its back with a red exclamation mark?
Laurence Piette
No it's only showing Android.
Photo of Sophia
Can you provide a screenshot Laurence? Perhaps one taken with another camera? :) Or can you describe the Android?
Laurence Piette
it's only the word Android. There's no little "emoticon" only the word android
Photo of Sophia
Ooh I'm sorry Laurence, if just a normal reset doesn't work, I'm at at a loss... but I know a few here are absolute Android gurus and I'll try to flag them to answer your question. Hang tight :)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
You may need to do a hard reset on the phone if it will not boot past this screen. This will wipe all data on the phone and restore it to an out of the box state. If necessary, here is the procedure:
• Take out battery, memory card and SIM
• Put battery back in phone (DO NOT TURN ON)
• Hold down the POWER/LOCK Key + HOME KEY + DOWN VOLUME KEY for approx 10 seconds until phone starts to come on. Release the buttons as the phone comes on.
• Phone will reset as it comes on.
Laurence Piette
Thank you very very much! My phone is ok ! :) xx
