HELP asap
I can't call out on my phone,, says no service , and can't send text messages as well???
I"ve had my phone and serve since 2006/7 same number ,, no issues? are you having issues on your end??
Photo of Christopher Willmott
Photo of Sophia
Sophia, Mobile Master
  • 142,994 Points 100k badge 2x thumb
Don't think there are any Koodo issues, Christopher, whereabouts are you? Did you check the settings if Koodo is selected (or selectable) from the list of providers? Perhaps the SIM card got damaged, or are you in a different area? Could be lots of things (including forgotten to pay the bill, lol) so let's troubleshoot :)
Photo of Dennis
Dennis, Mobile Master
  • 196,652 Points 100k badge 2x thumb
Did you try pulling out the battery and sim for a few and then restarting your phone?
A phone from 06/07 is pretty old. Could be that it's time has come
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
What model of phone are you using?
You could check that you're in the correct network mode.
[protip: 3G/HSPA/WCDMA = :), 2G/GSM = no service = :(.]
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Depening on the area your in, CDMA network has been shutdown(alberta im pretty sure and for sure Saskatchewan) So if your in this area your phone wont work.
other then that it should be working. pull out the battery like metioned above. if that doesnt work call technical support :) 18669956636 #6 for tech
Photo of Curtules
Curtules
I'd like to take this opportunity to clear up a little misconception or two on the shutdown of CDMA.
You're right that Saskatchewan is getting the whole network shut down (Sasktel's call, not Telus/Koodo) but the only thing officially scheduled for shutdown in BC and Alberta is the EVDO data, not the whole network. This just means that CDMA devices in BC and Alberta will be stuck with a 1X data connection, which is significantly slower.
Also, no other provinces are scheduled for CDMA shutdown of any kind at this time.
HippieLongstocking
CDMA network turndown in Saskatchewan will take place on April 30, 2014
This impacts voice and data users who currently have a 306 and 639 CDMA area code
Customers who do not upgrade to a 4G device prior to April 30, 2014 will be cancelled
Customers can reactivate their accounts with their old number within 90 days.
If a customer wants to reactivate, they can reactivate on a 4G phone with $100 towards the device. The difference will need to be placed on Tab (customer is subject to approved credit) .
Photo of Curtules
Curtules
Now that that's cleared up, Teabird has a point. Customer's with the same phone since Koodo's inception are probably using a CDMA phone, so if you live in Saskatchewqn that might be your problem.
