Help ! ASAP!
My samsung galaxy s2 was stolen. Can I find it with the ip addy? IMEI number? Or gps ? It's per ayes and I havent suspended my service yet. And how do I check messages with another phone?
Photo of Curtis Hottman
Curtis Hottman
If you enabled Android device manager, or installed an app to track it then yes however, if someone stole it they could be using it to rack up all kinds of charges that you are responsible for. Honestly you'd be better off to suspend it and cut your losses.
Edit : I just noticed you're on prepaid sorry. So your losses would just be the balance on your account. But still I wouldn't want to loose my balance. If you didn't install a security app on this phone, make sure you do on the next one.
Photo of quasarito
quasarito
Since you have an Android phone, go here:
https://www.google.com/android/device...
If you have tracking enabled, it will show the last known location of your phone.
If you do not, then you are probably out of luck and should look into buying another phone.
Photo of Bill Melater
Bill Melater
  • 2,954 Points 2k badge 2x thumb
Thanks for posting an interesting topic Curtis. I hope you find your phone. :)
quasarito: I just tried the link you provided, and it located my phone perfectly. Thanks for the tip!
Photo of Moto G
Moto G
  • 6,066 Points 5k badge 2x thumb
Hey Bill. Have you tried finding your phone with the Motorola ID device yet?
Bill Melater
Hey M.G.
No I haven't. How do I do that?
Bill Melater
Found the website, but not working. Will try again later. Thank for the info!!!
Cheers,
Photo of Moto G
Moto G
I've not tried yet. Just wondering if you did and if was easier/ harder than the Android method.
Bill Melater
Android was simple and VERY exact.
Very impressed.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
To answer the second part of your question, you can check vm from another line by calling your cellphone number and pressing '*‘ when the vm message starts. From there it's just like checking from your cell phone.
