Help
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
My BB curve will not send random texts, saying Mobile equipment status failed, is there a problem with the network? I am in Grande Prairie, Alberta
Photo of Lori Rice
Lori Rice
  • 90 Points 75 badge 2x thumb
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Do you know someone there in GP having the same issue ?
But you can try a battery pull out , keep the phone like that for a minimum of one minutes and then turn it back it should be fixed.
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
Check also firewall is not blocking you from sending SMS.
Photo of Lori Rice
Lori Rice
no, my bf has a koodo phone, and is not experiencing this. I have removed my battery X2. Thanks Though..
Photo of e-wizard
e-wizard
  • 350 Points 250 badge 2x thumb
It would be a good idea to try removing the battery and leaving it out for some time and then putting it back, however, if by doing this the system doesn't get re-established, you will need to contact tech support.
Photo of Lori Rice
Lori Rice
Tried this X2. I will have to contact them. Thank You
Photo of MatB
MatB
Press X6 for Tech Support 1-866-995-6636 from different line.
