help with data usage issues. I'm supposed to have 10 gb
  • Updated 6 months ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 10GB plan
I changed my base plan. and used up my data add on. now it says my data is turned off and I have to pay $7/100mb. but I'm supposed to have 10gb?
Photo of Destiny Fox
Destiny Fox
  • 124 Points 100 badge 2x thumb
Posted 6 months ago
Photo of Sophia
Sophia, Mobile Master
  • 143,064 Points 100k badge 2x thumb
The 10GB plan was only for new customers, so you can't have changed your plan to it, Destiny. What do the details of your plan say how much data you have?
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
https://community.koodomobile.com/koo...
Turns out OP got the standard priced 10gb plan.
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
Try restarting your phone?
This is just a stab in the dark.
Otherwise you will need to contact Koodo to figure out why your data has been paused when you new plan has 10GB.  These are the issues when you try to change plans mid-billing cycle.  it can be confusing and can trip up the system too
