help with account
  • Updated 2 weeks ago
Please help!
Photo of Suzanne Relick
Suzanne Relick
  • anxious
Posted 2 weeks ago
Photo of David
David, Mobile Master
  • 96,110 Points 50k badge 2x thumb
How?
A bit more information describing the issue you are having would allow folks to offer suggestions.
Suzanne Relick
I received a text at 2:00 a.m. saying welcome to u.s. etc. I’m at home in bc canada
Photo of David
  • 95,968 Points 50k badge 2x thumb
If you are in certain parts of southern BC, it is possible that if your local tower stopped broadcasting, a nearby US tower became the stronger signal.
Suzanne Relick
My phone is very old & starting to act up a bit. Could this be a factor?
Photo of Dinh
Dinh, Mobile Master
  • 45,162 Points 20k badge 2x thumb
@Suzanne: if you are using iPhone, you could go to settings -> cellular --> cellular data option --> cellular data network --> manually select Koodo. That would help.
Photo of srlawren
srlawren
  • 5,702 Points 5k badge 2x thumb
This also works on Android phones.  The process may vary a bit by model, but basically you go to Settings, SIM & Network (or something similarly named--on a Samsung you may need to go to Connections I think it's called), then if you have a dual-SIM phone tap on the slot with your Koodo card, then tap on Network operators, and toggle Choose automatically from on to off and choose Koodo.  If you ever want to actually travel and roam, turn this setting back to automatic.
Suzanne Relick
Thanks all - I spoke to a real person & all is right.
