HELP verizon s4 cellular data
  • Updated 2 years ago
Photo of Brian Kimeli
Brian Kimeli
  • 84 Points 75 badge 2x thumb
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,622 Points 50k badge 2x thumb
Verizon handset may not be compatible with Koodo network. They still use CDMA technology which has been phased out in most of urban Canada.
From the specs, as long as the Sim slot is unlocked, you may be able to use this device.
Does the phone part work with a koodo Sim inserted?
Goto
Settings...wireless and networks....more....mobile networks....access point names
Make sure your APN is setup correctly, if not then you'll need to add it.
