Help! Texting other Iphones without data
Why can't I receive text messages from other Iphones without a wireless connect/iondata/iMessage. Shouldn't I be able to text normally? I can send texts out but I won't receive them until I am connected to the Internet. I want to text normally without setting my data back up.
Photo of Aηɢιє♪
Aηɢιє♪
  • 80 Points 75 badge 2x thumb
  • frustrated
Photo of Sheila
Sheila
  • 1,780 Points 1k badge 2x thumb
Is this always the case or did this crop up recently? You may want to check out your settings
Photo of Aηɢιє♪
Aηɢιє♪
Right after I got my data blocked it occurred :c I only have 50mb on my plan and I don't want to go over it by accident so I simply just shut it down.
Photo of David
David, Mobile Master
You might find buying a little more data the best option. You would then be using your phone as designed, and won't need to apply these work-arounds.
You may find this thread helpful :
https://c.getsatisfaction.com/koodo/t...
Photo of BobTheElectrician
BobTheElectrician
  • 67,162 Points 50k badge 2x thumb
What happens if you send yourself a text while you are away from a wifi connection?
This should force your text connection to look for the phone network (not data).
Photo of David
If you have a data block on your phone, iMessages from your friends will not reach you unless they have turned on the Settings > Messages > Send as SMS on their phone. If you do not wish to have a data plan on your phone, it is best to turn off Messages altogether.
Also make sure they are sending Messages to your phone number, and not your Apple ID.
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
Hey there Angie.
My best solution is to close iMessage altogether because like that you won't have any further complications.
http://www.idownloadblog.com/2014/05/...
