help. need to change address. Self Serve will not recognize my new address
  • 2
  • Updated 2 years ago
Can't get my billing address changed.
Photo of Gerald  Smith
Gerald Smith
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
Can you give an example address with the format you are using?If you go to canadapost.com you can put it in fo postal code / address finder and it will give you a specific format usually a that one should work IIRC.
