Help! Mobile Data problem!
  • Updated 2 years ago
I have an Alcatel Idol. I am able to connect to WiFi with no problems but not with mobile data. I have checked with my carrier and I have plenty of data & I have done a factory reset and it did not help. Does anyone have any other suggestions on what might be the problem? Thanks!
Photo of Kylie Benbow
Kylie Benbow
  • 92 Points 75 badge 2x thumb
  • unsure
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,216 Points 50k badge 2x thumb
Is this a sudden problem? Check out your APN in the mobile networks settings
Kylie Benbow
It's been like this for a couple of weeks. Works great with WiFi but as soon as I leave home or not around another open WiFi connection I cannot connect with the Internet. At first I thought I was over my data usage but I have plenty of data
Photo of Goran
Goran, Mobile Master
  • 97,164 Points 50k badge 2x thumb
Can you confirm please whether or not you ollowed Bob's suggestion to check your APN settings? Also do you have data enabled in settings? A factory reset should default data on but you never know.
Kylie Benbow
Bob the electrician you are awesome!! Thanks so much for your help and thank you for your suggestion Goran.
