Help meee!
  • Updated 2 years ago
If I want to buy the Samsung A5 (it's a$0 phone at Best Buy) is all I have to do is payoff my tab I have with Koodo? I'd approximate the help!
Photo of Carlie
Carlie
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
Yes , you simply pay off your tab and go get a new phone through them. Easy as pie. Tab and current bill to be safe. Also I recommend upgrading a few days before your monthly cycle ends to avoid any pro ration charges.
Photo of Carlie
Carlie
Thank you so so so much!!! So my tab is like $200 so that's all I'm paying??
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
Log into self serve > View tab balance > Pay off tab
Your remaining tab balance will be added to your next bill
Go to a store and upgrade your phone.
" it's a$0 phone at Best Buy..."
- It means that you pay $0 upfront and You will pay $15/mo tab charge for next 24 months.
Photo of Sam Dmitruk
Sam Dmitruk
  • 384 Points 250 badge 2x thumb
You don't have to go to Koodo to pay off your tab before upgrading.  Your tab balance will be billed to you after you upgrade at Best Buy
Photo of Chadwick
Sam. I believe u have to request it to be paid off in self serve before u can upgrade as ur tab has to be 0$ before u can upgrade.
Sam Dmitruk
I've actually never seen that.  I used to work for a third-party retailer that serviced Koodo.  Generally unless you were on a spending limit (or owed past-due bills) you did have the option to have the tab billed.
Photo of Chadwick
That's what Im saying. U go to self serve. Click pay off tab and it goes on ur bill. But u have to select pay tab before yu can upgrade and then pay it when ur next bill comes in.
