HELP! iphone 5c
how do i get my apps under my use for cellular data? for example. facebook is not under my cellular data so it wont let me us it, i have downloaded the app already, Iphone 5c
Photo of Christine Harper
Christine Harper
Posted 3 years ago
Photo of Ivan
Ivan, Mobile Master
Christine Harper
i have already been to that site, under my "usage for cellular data" it only has facetime and passbook, it doesnt have all the other apps under it, i wanna know how to get my other apps under it
Photo of Ivan
Ivan, Mobile Master
The "usage for cellular data" section should have every installed app that uses data. I've never seen it not show up. Try the following:
1. Uninstall the Facebook app.
2. Reinstall the app.
Does it show up now? If not, go to Settings > Facebook. You should have a screen like this:
Try tapping on the tab that I've outlined in red. I don't have an iOS device handy at the moment so I can't check what comes up. See if there's a setting in there that you can toggle.
Christine Harper
i know its weird, i have friends that are all about how iphones work and what not, they couldnt even figure it out which was weird, it didnt work when i uninstalled it and re installed it and the first photo is what pops up on my data, and the second one is after i click my settings in my facebook
Christine Harper
